SSDriver
- California
- Electrician
I need to move the location of a service for a customer. I will replacing their existing 200A meter/main panel with a load center and installing a new 200A meter/main on a different side of the house. Both panels will be semi-flush. I was looking at installing a Siemens MC2040B1200F 200A Meter/Main in the new location and either using feed through lugs or a 200 Amp branch circuit breaker. I found siemens ELCK225 feed through lug kit but wasn't sure if this ok to use in that panel or possibly the QN2200 (200 amp breaker) on that panel. The spec sheets I have found are useless on what accessories or breakers are allowed. Any help would be great. I mostly work on commercial and feed through lugs are a lot more common. The new meter/main panel has to be semi-flush due to working space clearance requirements.
