Looking for some help with purchasing a breaker
Breaker Boy
New User
LA, CA, USA
Here's the deal, I'm looking to find out if I can purchase a Murray breaker with a slightly different landing spot than what they sell at my local Lowe's.
The breaker I want is similar to a MP23020, but I need the teeth to be slightly different. The ones they sell locally have the shallow teeth for snapping into the bus and the panel I'm working on requires the longer, or deeper, teeth. Any help would be much appreciated, many thanks.
20A single pole
30A double pole tied to the one below it
30A double pole tied to the one above it
20A single pole
These are the tandem type breakers, so I'm looking to slot four positions into two normal sized spots, if that makes any sense.
480sparky
Iowegia
If, by 'teeth', you're referring to the depth of the slot in the breaker for the bus bar to slip into, my guess is you're looking for a tandem breaker with shallow slots to prevent it from being installed onto bus bars that don't have a corresponding notch in them. This is a rejection method, and should tell you you can't be putting tandems in that panel.
GoldDigger
Placerville, CA, USA
Retired PV System Designer
Or at least not in that bus position in the panel.
LarryFine
Henrico County, VA
Electrical Contractor
Sounds to me like that's what he has, and wants the style with the deep slot to fit the non-notched stabs.
That I agree with. And, with apologies to the OP despite his user name if I'm wrong, it smells slightly DIY.
