I have an outlet with 120V from hot to ground, but shows only 14V from hot to neutral...I assume it is either a bad joint or a bad spot in the neutral somewhere....however the building is very old and the wiring is a nightmare, it was a two story home, that is now two seperate businesses...does anyone have any good ideas or tips for tracing the neutral back?? All the raceways are obviously concealed, so I was going to try to open all the boxes nearby and pull the neutral to see which way it runs, and hopefully find where it is good and repull the neutral if necessary......thanks for any help or advice
