I have a question concerning cable termination requirements for low voltage and high voltage lines and their termination points. The college I work for has recently installed Code Blue Emergency Phones at all of its campuses and a question has come up concerning the terminations of the low and high voltage lines for these phones, naturally the question was raised after the project was completed. One of our Telephone Technicians, retired US West, went to check one of the units for dial tone. While checking this unit he found that both the high voltage (110 volts) and the low voltage wires (voice) co-occupy the last five feet (5?) of space. For each phone two separate conduits are installed; one for low voltage and one for high voltage. The conduits for voice (low voltage) are home run from our MDF Rooms to the base of the poles the phones is mounted. The conduits for the electric lines (110 volts) are home-run from the nearest electrical box to the base of the pole the phone is mounted on ? both conduits end at the base of the pole the Code Blue unit is mounted on. Starting at the base of the pole both low and high voltage lines start to occupy a single area, the pole itself, which is against code, according to our technician
In each phone the voice line terminates in an RJ11 and the electrical lines terminate to an exposed screw posts (no covers over the screw posts), which are located a few inches above the voice line. The area of termination is dark and small and requires the technician to reach into the enclosed area, blindly.
As I stated, our technician has indicated this does not comply with the Electrical Code and would like these units to be in code. This is where I get lost ? I have completed some searches for information concerning this matter and have not been able to find any answers or codes ? Wanting to comply with all Electrical Codes I need to find them first - Can anyone help, or point me in the right direction?
I would appreciate any assistance provided.
Thanks - Frank
Thanks - Frank
