brazosdog02
- Texas
Not sure if you guys can help me or not.
I have a genset that was installed in my home before I moved in. Unfortunately, ALL of the genset information is completely unreadable. But, as I understand it, my generator is a 25-28hp Lombardini Diesel water cooled motor. I have zero information on the genset attached to it, but it runs at 3600 rpm and is hooked up to a GE Zenith Controls automatic transfer switch with a 50A breaker. It probably will handle more, but they put a 50A on it to be safe. It runs all three freezers/fridges and all the lights in a portion of my home as well as the water wells. I have the transfer switch information if needed....so...the problem:
I fired it up yesterday, and the automatic transfer switch would not recognize that emergency power was available. There are two red lights that come on when the generator normally runs. In the past, when this happened, the issue was the capacitors in the genset. Those were replaced wtih two 25uF capacitors and it was working fine until yesterday.
[FONT=verdana, geneva, lucida, lucida grande, arial, helvetica, sans-serif]I tested the capacitors, and they both check out OK on my Klein Voltmeter. The voltage output from the generator when it is running is at 21 volts or so on each leg. That is why my ATS is not seeing it.
I had this same problem a while back when they replaced my capacitors. But this time, the capacitors seem to check out OK. What else can cause this?[/FONT]
