low profile cans for soffitt
masterinbama
Any one here have a source for small remodel cans. They need to be rather shallow because the customer wants them in the soffitts of his house. The roof is very low pitched, so I have very little overhead clearance.I can go with low voltage if need be, they might even be better.
Dennis Alwon
Chapel Hill, NC
Retired Electrical Contractor
Halo makes a H27 RT-- remodel as well as a open construction can- H27T. Both are non IC and an 1" or so shallower than the H7 cans. Same diameter.
elights_2035_38971719
They do make an H27 ict I found these will fit 2x6 joists
masterinbama
Thanks guys I think I can use something from Lithonia. My biggest problem is the soffitt is not framed normally basically the brake metal on the facia and the freeze hold the vinyl up so I will have to cut out some luan plywood backers to support these lights. I don't do very much residential retrofit work ,but the customer is a process engineer i do a lot of work for and he knows I'm a little slow until February
