210.63 --Heating, Air-Conditioning, and Refrigeration Equipment Outlet.
440.1 scope many will claim that since this evaporator unit doesn't contain a hermetic compressor is not a 440 application but rather a 422 application.
I think they maybe could use a little more clarification as to what they intend though as if this were the inside unit of a heat pump system that may be called heating equipment.
I think the intent is that HVAC tech's need to have a 120 volt receptacle in vicinity wherever they connect charging, reclaim, vaccum equipment, and that is usually near where the compressor of those systems is located. That is about the only routine procedure that usually requires a 120 volt powered tool to perform the procedure.
But that said it still kind of goes against 90.1 and is a design specification to a certain extent and should maybe be a design decision instead of a code requirement:huh:
