Twoskinsoneman
- West Virginia, USA NEC: 2020
- Facility Senior Electrician
Hi. Amazing forum. Such an incredible wealth of knowledge.
My question is concerning relays and low voltage to control them. My job is to design electrical systems for government command and communications vehicles. We as a company only wire to the highest safety standards but we also aren't technically governed by anyone including the NEC. We frequently use approved electromechanical relays to switch on and off 120vac loads. We often use relays such as these http://www.magnecraft.com/type_results.php?id=1
Anyway we use 12vdc to control these relays because it is so safe. You very rarely have to worry about getting shocked from 12 volts (only under prime conditions). Is this type of configuration acceptable for residential wiring? I've tried to research diligently in NEC but as far as I can see it specifically mentions low voltage lighting. Does it distinguish from control circuits?
Specifically I am currently wiring my garage and I was thinking it would be cool if I could turn on my air compressor from outside without unlocking the garage and going in. A low voltage circuit on a switch outside could control a relay inside the circuit breaker panel.
Is this to code? It seems very safe. Especially with a regulated power supply to control the relay. You never have to worry about a fire if your power supply can only put out 300ma even when shorted.
Thanks very much.
Jack
Thanks very much.
Jack
