Tim Jaramillo
I have six cabnets that need LED puck lights. Rather then buying a transformer for every location I ran #18 lamp wire to every location. Did not know if I might find a proublem with voltage drop due to the distance of each run (about 25'). if so can I use another transformer with a higher volts or amps out put? the transformer it comes with is 12v 1a
