New EE
- California
Is it permissible to run 16 awg 600 volt insulated cabling (being used for a 16 vac transformer) in the same conduit where there is 18/2 unshielded, 18/6 shielded, and CAT5e cabling in the conduit?
I wanted to provide only one conduit to go from a door that has a card reader and directory entry phone (that needs a 16 vac transformer to power it) and run all the wiring in the same conduit
from the door to the comm room but wasn't sure if I can run the 16 awg 600 volt insulated cabling in the same conduit with the other cabling per code. Thanks.
