WayneSeroka
Is it permissible to mix 300 volt insulation and 600 volt insulation cables in the same conduit, if all cables and conductors are low voltage (24V AC and less) or communications (shielded) ?
The conduit in question is between two cabinets where the maximum voltage present is 115vac.
