Have looked thru the code and cant find the answer to this. Many halls, rooms etc. are listed as having firewalls. Is there an area in the code that states you can not use a lo-voltage cut in in a fire rated wall? All walls have drywall so are somewhat listed fire rated and a 4" sq. box mounted in the same wall had the factory drilled 1/4 " holes in it so ..........I just cant find a section stating you cant put these rings in a certain type of wall, especially fire rated.
