horrorsix
- Harrisburg PA
What is the difference between an electronic low voltage dimmer and a regular dimmer. I don't understand why you need an electronic dimmer to dim a transformer.
A regular dimmer, by virtue of how it chops the AC sine wave to do the dimming action, imposes a DC current on it's output which can cause transformer-based devices into core saturation or severe overheating. (As in letting out the magic smoke.)
An electronic type dimmer uses a different method of "modulating" the basic AC waveform so that it will have little or no DC current on its output.
If I could find them, I would post a picture of the two different waveforms and you can actually see the difference. But a regular dimmer basically flattens the tops and bottoms of a sine wave, and if you draw that out on a plot of amplitude and voltage, you'll see that the flat tops portion maintains a steady-state value (read: DC) over a much longer time that a "straight" sine wave.
A couple of dimmer output voltage waveforms.
Leading edge:
Trailing edge:
Unless the dimmers are faulty, there should no significant dc component in the voltage.
Trailing edge:
Gar this is a fluorescent dimmerUsing the Lutron SF-10P the phase shift control works with the transformer loaded or unload.
What is an "electronic dimmer"?
A dimmer that is designed to dim electronic low voltage transformers.
