- Bremerton, Washington
- Master Electrician
Question from one of my classes - I want to throw out to the forum
With Cable Tray (B Line 6" Ready Rail) will have in it "low voltage" such as radio coax, Class 2 alarm cables.
Also need a power and lighting branch circuit, 120/240 volts running in the same tray.
When is a divider needed?
For example, MC cable can be run with out a divider, and no separation is required- MC cable is a chapter 3 wiring method, same with AC, NM.
But what about tray cable (Art 336) which is also a chapter 3 wiring method?
For example, a 14-2 w/ ground jacketed tray cable?
Is the divider needed with conductors and not cables? A divider would be needed with single conductor tray cable, such as 4AWG.
