GG
- Ft.Worth, T.X.
Do you need to be licensed as an electrician if you are within the city limits and you want to install 24V landscape lights that are fed from a plug in transformer?
You are right about the voltage drop problem, but if the lights are installed correctly, you will not have open ground splices. We do about 50-70 installs a year and we do not allow splices, just quick connectors which we use liquid electrical tape to surround the quick lock.Originally posted by hardworkingstiff:
I think in NC you don't need to be licensed to install low voltage landscape lighting.
But...... IMO, most people don't consider the voltage drop problems with LV lighting. It's a big deal with the low voltage and relatively high current (as a % of voltage). Plus you have open in the ground splices. I bet a lot of those corrode quickly.
