woodduder
- West Central FL.
This seems the best section of forum for my question.
What is the advantage of low voltage lighting?
The reason I ask is because I was in BIG ORANGE yesterday and was looking at the remodel recessed lighting, 4", incandescent, 50 watt.
They carry a fixture that uses a GU-10 lamp which is 50 watt and operates at 120 volt.
It is a very simple and lightweight item to install.
They also carry a fixture that uses an MR-16 lamp which is 50 watt and operates at 12 volt with a heavy, bulky transformer attached to each one which seems to me to be just another part that would go bad eventually.
Both use a lamp with a 50 watt output. Do they not use the same amount of VA at their input?
Seems crazy to install a LOW VOLTAGE fixture if they do use the same VA.
Help me understand. Thanks
