Article 430.36
Comment 1: Article 430.36 of the code allows fuses for overload protection. To size the fuse for overload protection (as allowed by this article), I assume we have to use article 430.32 (A)(1) Separate Overload Device. So the fuse will be acting then as a separate overload device.
Question1: Is it correct to use article 430.32 (A)(1) Separate Overload Device to size the fuse when used as the overload device permitted by Article 430.36?
Comment 2: Since the fuse is used as an overload device, then there will ONLY be one overcurrent protection device in the motor circuit, the fuse. The fuse is acting both, as the short circuit protection and the overload device (obviously if sized according to 430.32 (A)(1).
Question 2: Is this correct?
