xguard
- Baton Rouge, LA
I have a Trane chiller. It has an external (customer supplied) low voltage circuit for a flow switch and motor starter auxiliary contact. So if the pump isn't running (no flow or pump starter not energized) the chiller is prevented from running.
These low voltage wires enter the combination motor starter disconnect, and land on the auxiliary contact. The coil voltage on the starter is 120 VAC, the pump voltage is 240 VAC. Is this low voltage circuit allowed to be in the same enclosure as the 120 VAC and 240 VAC circuits. I recall there are separation requirements in conduit but I didn't understand how that worked out when they are needed to be connected to the same device.
I realize there are different types of low voltage circuits, from the ancient trane literature and wiring diagrams it appears to be 24 VDC. It's not clear if it's class 2 or not.
