Low Voltage Outside Plant Conduit
ross
New member
NEC states electrical conduit can have 360 degrees in bends. How many degree in sweeps/bends are allowed between manholes for low voltage cable? Also, are opposing bends allowed? I can't find anything the the code book regarding this.
luke warmwater
Re: Low Voltage Outside Plant Conduit
Originally posted by ross:
NEC states electrical conduit can have 360 degrees in bends. How many degree in sweeps/bends are allowed between manholes for low voltage cable? 360.
Also, are opposing bends allowed? yes
I can't find anything the the code book regarding this. NEC only limits the number of bends, not where they are placed in run.
Todd
Nick
You state this is an outside plant installation. Every job I have done in the past 5 years has had a 180 degree max and the radius of the bends had to be 10 times the conduit diameter. I believe they get this from cable manufactures data and industry standards. I don?t know who you are doing the job for but they may have standards above and beyond the NEC.
