Grouch
- New York, NY
Hi all,
This is regarding table 680.8 under the 2008 NEC code cycle... We have existing low voltage cables (inside conduits) that run across a new indoor pool. According to section 680.8(C), we need to follow table 680.8 for conductors operating at 0 to 750 volts to ground, to determine the clearance required above the water level. The title of that column on the table reads "Insulated Cables, 0-750 Volts to Ground, Supported on and Cabled Together with a Solidly Grounded Bare Messenger or Solidly Grounded Neutral Conductor"... if the cables are in conduit, does this section even apply?
Thanks!
Thanks!
