- New Jersey
- Journeyman Electrician
This is under the 2008 NEC, I'm looking at some low voltage LED strip lights mounted about 6' laterally and 12" above the indoor pool deck on a wall. According to 411.4(B) these lights must be a minimum distance of 10' from the waters edge unless permitted by Article 680. I can't seem to find anything in 680 that would allow 12 volt lighting installed in this location. Am I missing something?
2008 NEC:
411.4(B) Pools, Spas, Fountains, and Similar Locations.
Lighting systems shall be installed not less than 3 m (10 ft) horizontally from the nearest edge of the water, unless permitted by Article 680.
