Billy D
- Massachusetts
I installed some Seagull under-cabinet lighting. The type of lighting is were you plug the lamp socket into the cord itself. I installed the transformer in the basement and snaked the low voltage wire in the wall and came out under the cabinet. The Seagull sales person tells me that the wire is not acceptable in a concealled wall.
Is this true and if so, what other alternitives are there in wiring the lights. Can I sleeve the low voltage cable through ENT tubing? The wall is insulated. Where in the code does it prohibit me from just running this type of wire inside the wall.
