n1hampton
- Indianapolis
I was challenged when I put a 22/6 Sheilded in the same chase as a NAC circuit for a Pyro MXL. Had permission from all parties to do this. I was stopped by a carpenter that took this to my boss who now wants to see if it is a code. Found nothing in NFPA-72/101 or fire alarm signaling handbook that would prevent this. I was referenced to the NEC to code 760.26(A). Can anyone clarify this code? Both are plenum rated. Fire panel is NFPA and UL approved. Nothing in the spec for either system recomends against this. 24vdc on the NAC and 6vdc on the reader wire.
Thanks for the help
Thanks for the help
