jjhoward
- Northern NJ
- Owner TJ Electric
Hello All,
First off, Happy Birthday to the US Marines!
And.. thank you all Veterans, tomorrow is Veterans Day, thank you for your service and sacrifice.
I am working a few Warmfloor installs (radiant floor heat).
This product is a 1 foot wide plastic mesh with flat, braided, tinned 14 awg cables embedded along its edges. To install this stuff:
1) Lay a length of this material on the surface to heat.
2) Expose the embedded the 14 awg flat braided cables at one end of the mat (cut into and remove the plastic).
3) Crimp the 24 volt lines (14 awg or 12 awg cable) from the xformer secondary to braided mat cable.
4) Cover with flooring materials (wood, tile etc.)
These lines are limited to 120VA (5 amps @ 24 volts). The transformers are Class 2 xformers.
Is it code compliant to lay the 24 volt lines from the xformer under the flooring? I am reading through article 725 but I am not seeing an answer to my question.
Thank you all.
Thank you all.
