Have a friend with several outdoor low voltage transformers feeding his landscape lights (12v). Right now he has them plugged into GFCI's on the outside ( the kind you buy with plug in cords like Malibu etc). Weather-moisture etc does trip the GFCi'S from time to time, which kills his landscape lights until he goes out to reset them .
Question is, can he direct wire the xfrmrs line side directly to the line circuit feeding the GFCI? Could not find anything in the code stating the xfrmrs had to be GFCI protected.
Thanks,
Thanks,
