NEC 600 indicates a disconnect required with in sight of the electric sign, no issue?s there when the letters or cabinet is Neon.
But we have not built any new signs in years using neon, now it is all low voltage 24 Volt or less LEDs. Many of the
high end retailer in malls do not want to see the disconnect switch in a separate J box. Several municipalities here no longer require a switch.
Several different building officials said they can not find anything on this.
ALARM SYSTEMS DO NOT REQUIRE IT, IS IT IN THE CODE, AND WHERE- OR UP FOR A CHANGE
