Ltg. Calc
Alwayslearningelec
NJ
Estimator
These are both for the same lighting. Voltage is 120v.
When I convert the watts to amps I get in the 400A range.
When I covert the KVA I get in the 200A range.
What am I doing wrong.
Well now that I actually do the formula myself instead of online calc.
KVA to Amps single phase = 1000X53/120 = 441A
Watts to Amps = watts/120v - 464.
So close, sorry.
So close, sorry.
Assuming it's a 208V- 3ph system, you wouldn't want to use 120V to figure out the current.
And the kVA can't be less than the kW.
And the kVA can't be less than the kW.h figuring total amps for the lighting. Little help, thanks
So how would you approach figuring total load in amps for lighting? Little help, thanks
