Thanks for the good info. And the sarcastic question.The lugs are 'universally listed" rather than being specific to the panel.
The panel label is very specific and takes into account the temperature rise, wire bending space, and SCCR pull out requirements of its UL Listing.
Which listing is more important to you?
The lugs are actually the size we want. The panel label is the problem.Can't the lugs on a panel be changed? We often get them without lugs.
To Jim's point about the listing you're not going to end up with an issue with bending space when using a conductor smaller than what's on the label. I would reach out to Siemens and get something in writing.The lugs are actually the size we want. The panel label is the problem.
Yep.To Jim's point about the listing you're not going to end up with an issue with bending space when using a conductor smaller than what's on the label. I would reach out to Siemens and get something in writing.
