on 9/13 someone posted a picture showing aservice disc. with two lugs installed on the bottom of the enclosure that had a green gec and another black gec.because that enclosure comes with only enough lugs for the 2 neutrals and the egc to the feeder panel,you have to add a lug either inside the enclosure using the pretapped threaded hole or scrape the paint on the outside and attach the lug with nuts and bolts or a 10-32 tapping thread forming screw.the tek screws used in the picture from 9/13 are a violation.the installer probably would be better off using a split bolt to attach the #6 to the #4.even though the 10-32screw is code compliant i wouldn't use it for this application.
