Efficacy and Efficiency
Welcome to the Forum,
I'm unsure of your application or original lighting source, but assuming it's non-LED and fluorescent for example let's look at the following:
Efficacy - Lumens Per Watt
Efficiency - How many lumens actually escape the fixture
LED sources - Most LED sources are tested as a complete system (efficiency is 100% typically).
Fluorescent Lamps - Lamps are given a lumen rating, but when installed in a fixture (2x4) for example, not all of those lumens are escaping.
We see crossovers of the following all the time: 32W TT (~2000 Lumens) Fluorescent Can light to a 12W LED (~1200 Lumens). The reason these match in swapping them out is because the efficiency of the 32W TT fluorescent fixture is more around 60-70%.
I hope this helps.
