MNSparky
- Minneapolis, MN
- Electrical Contractor - 2023 NEC
Currently having an internal argument with myself over fixture support, need some opinions. We hung some exterior coach lights on a house where the box was cut in dead center on the j-block. The fixture strap attaches to the fixture off center towards the top so when we hung the fixtures, mounting the strap to the box, they look like they were hung too low and not centered vertically on the j-block. The fixture uses two decorative nuts screwed onto 8/32s to attach.
I feel that I can move the strap up, attaching the strap directly to the j-block with longer screws that bite into the plywood behind. I would consider this to be "securely supported" as required by 410.30(A). The box would still be fully concealed under the fixture, just not used for support. I got called on this by an inspector many years ago but I can't remember what his argument was. This is making me doubt myself.
The other side of me says the method I am using isn't listed in 410.36 as an approved means of support. The first disagrees, citing the many types of fixtures that are hung directly on a building's finish, like wallpacks. Side B argues they don't require a box as the fixture typically acts as one.
I am leaning towards if the connection is done in a approved box and the fixture is supported securely, either by the box or not, I'm good. Any thoughts?
