When using electronic ballasts the input power ratings are significantly less than a standard ballast (to produce the same lumen output as controlled ballasts in laboratory conditions). My standard fixtures are relatively inefficient, but still rated 112 VA and 58 VA (4 and 2 lamp T-8's, .99pf). Sometimes slightly different, the manufacturers' photometric (*.ies) files include this data. You do not add up the wattages of the individual lamps. This is a bad assumption. Supprisingly, a high(er) efficiency 2-F32T8 ballast, with .98pf, is as low as 47W, 75% of what one would regularly think. Check out Advanced ballasts' website.
