I have customer with 15 to 20 1500w lutron dimmers controlling lighting. we are replacing 3 to 4 a year. These dimmers control incandescent lights in chandler for ballroom. I was wondering if you guys know of an alternative to this type of application. unfortunatly these switches ganged 4 to 5 together. I think this creates to much heat and damages switches. All the dimmers that a ganged together 2 or more have this problem. If we switch to led we will need to replace the dimmers also so I am kind of running out of ideas. The only other option is to low wattage on lamps but they continue to put the higher wattage in fixture causing the problem to persist.
