- Tennessee NEC:2017
- Semi-Retired Electrician
I had a strange thing happen. I have a 2-gang box, with one Lutron Maestro fan & light control and just a regular switch. I removed the regular switch and replaced it with a Caseta wireless switch w/dimmer. I turned the power off and put in the Caseta. The only thing I did to the Maestro was remove the heat sink fins on the inside of the switch like you have to do with multiple dimmers. I buttoned everything back up, programmed the Pico remote to the Caseta, and tried the lights. Everything was good with the lights connected to the Caseta.
I was going to turn the ceiling fan on and got nothing, tried the fan lights, nothing. None of the LED indicator lights on the Maestro were on.
So I'm thinking a wire must have come loose when I was working in there so I took everything back apart. Couldn't find anything loose, and power feeds both switches. Both switches have power but the Maestro is dead. I called Lutron and the only thing they could tell me was there is some kind of arc protection inside these type switches and they can go out. Problem is they are not replaceable and nothing can be done other than get a new switch. Now as I said, I had the power off the whole time until the cover plate was back on. I don't know what would have caused the part to fail. The worst part is they don't make that model of Maestro anymore and no direct replacement.
Anyone ever had this problem?
