Are those a 3rd party? All the Lutron's I have used are clear and have square corners.Here are the plates and it shows a pico install to the backplate. Just fasten to the wall and put a cover plate on it
Yes, I think they are but that's what came up so I posted it rather than look for the othersAre those a 3rd party? All the Lutron's I have used are clear and have square corners.
You should use the screwless platesI have the mounting bracket but I found that the remote is just proud of the cover plate in this method
Are you removing the upper plastic piece from the bracket? It needs to be removed for direct wall mounting or the bracket will not sit flat on the wall.I have the mounting bracket but I found that the remote is just proud of the cover plate in this method
