I don't know of a receiver to go in a canopy.Do they make a receiver/switch unit that could be mounted in the canopy/j-box of a fixture that a Pico remote can operate?
I figure if I can tap power off a nearby smoke alarm for a light then I could maybe use a Pico to control that light...
I've seen those now that you mention it. Well, similar anyway. You screw the module into the light socket, then put in the bulb. Put the remote switch where you want it.I don't think there is an option with Caseta but we've had really good experience with Insteon. They have a micro module that is designed for exactly that.
Rob
The ones I was mentioning can be hardwired into a j-box. Here are some linksI've seen those now that you mention it. Well, similar anyway. You screw the module into the light socket, then put in the bulb. Put the remote switch where you want it.
I just did that with another install....I don't know of a receiver to go in a canopy.
What I have done in the past is to put a master switch in an attic or closet then put a Pico where they wanted a switch to control the light.
This product is similar to (maybe even the same thing) as what I saw used in a YouTube video that I watched last night. The ‘Tuber was one of those UK English electricians.The ones I was mentioning can be hardwired into a j-box. Here are some links
On/Off Micro Module — Insteon
www.insteon.com
Dimmer Micro Module — Insteon
www.insteon.com
We will typically control it with a wall dimmer.
Insteon Remote Control Dimmer Switch
Get complete local control of your automated lighting systems or remote control with your smartphone with this Remote Dimmer Light Switch.www.smarthome.com
Rob
