incoming Supply 11kv failed, new 11kv switch fitted by electricity supplier, before powering back on/and switch repair.........switchfuse to building 1500A per phase was isolated and locked OFF.....on the building incoming busbars (lv side)carried out resistance tests between phases...phase/neutral...phases/earth...all return values of 1.6 ohms.......there is the standard LV board monitoring amp/volts/earth leakage alarm,lamps, this is a 40 year old panel...on further inspection throughout building no signs of ANY damage issues on site...so went ahead and switched on???? everything worked AOK????......can anyone explain this???:?
