tedge
- Camden, ME
Hey all,
Ran into a new problem recently and thought someone could help. I took over a big job after the original EC went broke. In a walk in closet there are 2 120v lights and 2 12v puck lights on the same switch. The wiring goes through the 120v lights first then to a JB with a small 75W "Tombstone" type solid state transformer for the pucks. The HO then decides they want to put Lightolier Onset dimmers in the whole house. I've tried both the line voltage and inductive low voltage dimmers, but all the closet lights flicker when dimmed. I was told, and have found, that these transformers can be dimmed by regular line voltage dimmers with no problems.
So are the Onset digital dimmers more sensitive somehow, and do they make a specific dimmer for this purpose? Do I need to split the line voltage from the low voltage? Any thoughts?
