Buck Parrish
- NC & IN
I am installing some LV and 120 volt lights. I will use PVC under a slab. I am useing UF #12 and LV wire for the low voltage lights.
I would like to run my PVC under the slab then 90 up in to where a cinderblock wall will be. With connector and bushing on the end of the conduit. no box. Then go from their pull the wires up through the hollow parts of the cinderblock.To the 120 and the LV lights.
The wires will not by encased in concrete. Can I run UF and LV wire in the hollow parts of the cinder block? The uf will go in to the back of a box. The brown LV wire I will drill a hole through the block and stub it out for surface mounted lights.
