FaradayFF
- California
Hi All,
I was reviewing NEC Article 110 and it talks about working space requirements in front of and behind an energized equipment. I have a situation where client desires rear access to the lineup. My understanding is that rear access would be required for cable terminations. The cable terminations would be accomplished with the gear de-energized, so my interpretation that NEC Article 110 would not apply during installation and cable terminations.
Reviewing switchgear vendor design guides, I didn't see any guidance or recommendation on clearance requirements in the rear of the unit.
My question is, is it up to the designer to determine what this clearance should be from the rear of the switchgear to the wall? I don't imagine anyone accessing and removing the panels in the back of the gear with the unit energized, this would be more to provide adequate working space for an electrician installing the cabling before the commissioning of the lineup.
Thank you all for your thoughts.
EE
EE
