ItsHot
- A little piece of heaven!
I have problems with a 12 volt track fixture. This fixture is the "S" curve type, with 3 pendants an 2 spot heads.( 5 -50w=250w) Customer was told from shop where he purchased fixtures from while he was building home, that the transformer was more than likely bad.Since he was having problems. Homeowner purchases new transformer and calls on me. I get on-site to troubleshoot the fixture. Finally locate the transformer at a can-light in ceiling. Check voltage going into transformer..110.8 volts. The lights are not burning. Kill power,change out to new transformer. Lights come up for about 10 seconds and then go off.???? Check output voltage of "new" transformer with no low voltage at taps???Nothing? Go to dimmable switch location. There is one 1000w dimmer serving 3 switches. Load side of switch reads 120 volts...everthing else appears fine. I then "jump" out the transformers from a countertop receptacle to bypass switch to see what happens??? Nothing! After alternating the 2 transformers, and checking voltage I finally get the fixture to burn using the old/original transfomer. I let the fixture burn for about 10 miutes, while cycling the dimmer slide. Everything seems fine. This is with the circuit back on the switch at this point. I began to button everything back up only to have the fixture to lose power to lamps again!
I then triple check my connections.. they look good. I have a transfomer problem! The 2 transformers are identical.. LightTech brand, 120volt to12 volt, 300watt with thermal overload protection.I believe the fixture is also LightTech. Can't buy new stuff that works anymore!!Lamps are known to be good/ok, and are the correct 12 v /50w lamps for this application. Any comments or help is greatly appreciated! Thanks!!:smile:
