gravitydrno
Working on a commercial restaurant where they want LED tape lighting on the underside of each shelf on a two shelf hanging wine display. I was hoping to mount the transformer in the crawl space (using a weatherproof transformer for extra protection) and enter the wall up to a dimmer then from the switch up inside the wall to a wood beam, run along the top and then down through the beam onto the display. Reading through 725 it is my understanding that since the secondary is 12v drawing 1.1a I am running a class 2 circuit and any CL2 wire would be compliant inside the wall and need not be in conduit. I want a small cable size and was looking for suggestions,would a 18/2 thermostat cable work in this situation and be compliant?
