ma to hz
EC - retired
PF 70e.
I'm supplying the drive with 0-20 ma.
8 should = 30 hz if vfd set for 4-20
10ma=30 hz if set for vfd set for 0-20
81 & 82 equal 0&60
91 & 92 eqaul 60&0
My drive does not give me either at the given Input.
About 80%. ?
Which parameter am I missing?
Why is available network always furthest from project?
__dan
If it's 4 - 20 mA, zero is 0 - 4 mA. The span of the range is 16 mA. Half the range is 8 mA, added to the threshold value of 4 mA, 8 + 4 is 12 mA should indicate half of the range or 30Hz. Not sure if that's what you wanted..
