StarCat
Industrial Engineering Tech
- Moab, UT USA
- Imdustrial Engineering Technician - HVACR Electrical and Mechanical Systems
I am dealing with a Berkel FMS20 stand mixer. IN the day, these units were fairly well made. With that said they are neither easy or fun to work on.
Hobart has soaked up Berkel and for those unfamiliar, Hobart is also not fun to deal with and tends to sequester and hold all Tech Data behind a firewall.
Long story, I have an older model machine that was scrapped over several major component failures, lack of a service manual, and some parts being obsoleted.
I later found a service manual, and bought a second good used machine with no problems coming in. Getting this one apart the other day I noted that a design change was made and where there once was a single pole overload [Siemens 48DA18AA4] with 25A element, they have instead installed an ABC 8 AMP ceramic fuse. There is a transformer in 120V models that provides nominal 124-150 VAC to a solid state speed control that supplies a 90 VDC motor.
Due to the extreme time involved in getting at the new design sequence, fuse......
That fuse is on the output side of the DC speed control.
It would be very desirable to install a single pole overload which can be accessed from above by simply pulling the motor, as in the older design unit. My question is would I be good using an 8 AMP element in that same overload assembly?
