We have a machine (OLD) that the disconnect no longer works. The disconnect is no longer available, It is flanged mounted to the control box,the flange mount operates a lever that turns off the disconnect in the control box. Is it within OSHA standards to mount a Fusiable disconnect on the outside of the control box for control of power to the machine, If we remove the old disconnect and cover the hole where the old switch handle used to be.thanks
