mehdi1351
- New Zealand
- Electrical Engineer
Hello all,
As I am not familiar with US compliance requirement for the machine safety, would appreciate if anyone can assist me on the following:
1- Does an E-stop button on the local control panel is enough to stop the machine or should we install a pull-cord or Trip-wire on the both side of filter press and link it into the PLC to stop the machine?
2- Does movable guards required on the hydraulic power pack? Currently many manufacturer doesn't propose any movable guards interlock to the filter-press closed limit switch. The safety concern is, when the filter-press closed (under high pressure hydraulic) and if someone release the hydraulic lever (i.e open the filter press), then the high pressure liquid can splash and make a safety concern for someone nearby the device.
3- Generally is there any standard I should comply with for machine safety in US?
