In the theater/entertainment lighting world we use lots of 12/14 TPR cable, feeding six circuits, frequently loaded to near 20 amps each. My question is about coiling excess in-use cable. Apparently it is standard practice to figure eight the coil to reduce heat & the magnetic field produced by a fully loaded cable (as apposed to a circle coil). I could see this being helpful with dispersing heat (shorter stack, more air space) but don?t understand any magnetic field issues. Each circuit has its own neutral and would normally consist of 120 volts using all three phases or possibly just one phase (based on the configuration of the dimmer racks) but always with their own neutral. Thanks for any and all input!
Link to product mentioned:
http://www.lexproducts.com/cs/Entertainment_product_line?market=Entertainment&productLineId=17
