Magnetic Motors
mspicka
Colorado
Journeyman Electrician
Attraction or repulsion... Why would you use one over the other?
I am reading about power sources and it came up the there are two types of magnetic power sources. I am struggling to find the reason one would be used over the other. And in reading, attraction has a 5-10% advantage.
In standard three phase motors, the (sum of) the stator magnetic field rotates while the rotor poles are N - S magnets that follow the rotating field, in lockstep for synchonous type, and with slip for induction type. I believe that is arranged attractive. Servo motors and ECM type simulate synchonous type but with PM permanent magnets at the rotor and more field poles (typically).
Why induction type this way, my guess would be jungle rules, most impressive brute force delivery at the lowest cost over the long term, other factors weighing less.
Now with EV;s, there's billions of dollars being spent annually just in engineering the next breakthrough battery, and probably some similar quantity spent trying to engineer the next breakthrough DC powered (probably ECM or Servo type field control). The motors are extremely high tech with PM magnets arranged Hallbach effect for magnetic field bending and other tricks.
The why would be for leading performance battery life in a higher torque less weight package, with marketing bragging rights 0 - 60 and 1/4 mile times. Tesla's early market target was for early adopters who would pay the price to beta test whatever they put on the market. They're selling high priced performance and are probably trying everything to lead and stay there. The million mile car is coming later, right now they're selling ludicrous 10 second performance time.
How they do that you would have to keep reading for.
I enjoyed this answer but I was looking for a more simplistic answer. I am making a power point presentation for beginners and was trying to answer it a bit easier.
It’s detailed but some things are blatantly wrong.
In an induction motor it always slightly lags the rotating magnetic field. The way that you create a rotor current is by cutting the magnetic lines if force. If the rotor speed matched the synchronous speed then rotor current and thus torque equals zeto, not enough to even sustain itself so this is a theoretical condition only.
A similar condition exists in permanent magnet motors. Not sure what you mean by attraction/repulsion but this is one area where we can adjust this somewhat. In a stepper motor we generally apply current to one set of poles and the permanent magnet rotor advances to that step. We do it again and it advances again. We continue the process to cause more or less continuous rotation but there is another option. We can also pulse width modulate two adjacent steps so that we can finely control the rotor position. This is called microstepping. Similar things can also be achieved in BLDC style motors which are more efficient. In fact I should stop here and mention that because they don’t have a rotor current BLDC (brushless DC) motors can achieve high torque and efficiency although there are scaling limits so they are limited in size.
With both of them and actually on any motor if you reversed the rotation of the applied field then the motor becomes a “brake” which is really a generator. For a period of time power flows backward. Continue past idle and it motors again but in the opposite direction. In fact if an external source continues to rotate the shaft it’s a true generator. People rarely think of it that way but generators and motors are the same thing. The only difference is the power flow direction.
Synchronous motors are the only ones I know of where the terms attraction/repulsion might apply. The rotor voltage is DC. The stator is AC. If you adjust the rotor voltage it causes the phase angle to change from nearly 90 degrees leading to 90 degrees lagging. The speed is synchronous. As it goes through leading angles instead of acting inductive and consuming Vars it will act capacitive and produce them! At 0 vars the power factor is zero and the current is at a minimum, making transformer I-squared losses a minimum. As you move into leading power factor the resulting vars cancel those created by other inductive loads, benefitting the entire system.
Could you explain what you mean by 'magnetic power sources'?
I think understanding your question will be necessary before getting into different motor types.
Jon
You are probably thinking of magnetic forces that are either attractive or repulsive, rather than magnetic power sources. The power for a motor doesn't come from the permanent magnet. If you take energy out of a permanent magnet, the magnetization will deplete and it will turn back in to ordinary iron. The energy in the permanent magnet ideally remains constant throughout the motor's service life.
The power in a motor comes from the electrical energy source as it energizes the windings into becoming an electromagnet. That electromagnet will then attract and/or repel the permanent magnets at different positions throughout the rotation. The permanent magnet (assuming it is the stator) is there to set up the field that the electromagnet rotor aims to align with, as it rotates.
People, I am the person that has been talking about using two forms of energy for one output system for about 25 years now.
Mspicka: question: why 2 forms- first, My systems do not use electrical power to run - second, once built they start running on their own no outside force needed. third, once running they keep running unless stopped by greater force than the motor puts out.
As we all know for every action there is an equal and opposite reaction, this is action = 1 counter reaction = neg 1 so 1 - 1 = 0 conservation of energy.
Over may years I have developed a way of using 2 energy sources for on output device. this means 2 - 1 = 1 with this type of technology there is 1 output energy usable because the counter reaction also has it's own energy source.
The technology described is not advertised on any normal website, unless you know what to look for it will not be found.
And the funny thing is People all want to find this type of technology, but I can tell you where to find it and still you will never look.
cracks me up, Really. Because I will give the designs for free to anyone that ask. And yes the systems do work.
Thanks, Tom Wlazlak - Corinne Technical Design Engineering - EttCM Energy technology - Magnagravity technology - Vashon island, Washington
Sent from my iPad using Tapatalk
Just say rotating field of the stator pushes/attracts the magnetic field of the Rotor. Also Remember 2 things, a motor is a transformer with a rotating secondary, and a motor that is not moting is a generator. these are very simple explanations. 🙂
Attraction is a motor, repulsion is a generator the way I read the OP query.
Induction motors have slip (rotor field lags stator field), induction generator rotor lead stator so could be termed repulsion.
Or.... (back to the original)
At a very basic level, when two things attract, the force vectors pull them directly towards each other in a straight line; when they repel they try to push away in any direction possible so if you want a straight line, you have to establish physical limits to get it. These push-pull dynamics are easily demonstrated with a pair of magnets or a piece of string (compare pulling or pushing on end of it).
When you get into motors, it's easier to design for magnet pairs pulling at each other than for magnets trying to play "keep away" (my recollection of Rotating Machines is fuzzy after 40+ years).
