Magnetic only Motor Circuit Protection Breaker
Venkatec2018
Missouri
Hello all,
Can someone please help me with my below questions ?
I have a Square D I-Line distribution panel with six breakers. There are 6 breakers in this I-Line distribution panel. Each breaker feeds one motor starter circuit. The connection is as shown below.
I-Line panel Feeder Breaker -> Fused Disconnect -> Starter Panel (with contactor & overload relay) -> Motor.
The distance between I-Line panel feeder breaker to starter panel is 30 to 40 feet. The starter panel has overload inside for thermal protection. The starter panel also has fused disconnect.
Question 1
Is it ok to use Motor Circuit Protector breaker with only magnetic trip in the I-Line panel ?
Question 2
Does the I-Line panel feeder breaker need to provide both thermal and magnetic protection ?
Question 3
Which section of NEC is applicable to this scenario ?
Question 4
Ideally when overload condition happens, the overload relay inside my starter panel will trip protecting the breaker and cable. In addition to this, should the I-Line feeder breaker provide thermal protection for cable running between I-Line panel and starter panel ?
Thanks & Regards,
Venkat
augie47
Tennessee
1 No
The rest of your questions are answered by 430.52(C)(3)
ITs can only be used as part of a listed combination motor controller.
Jraef
Moderator, OTD
Electrical Engineer
1 No
+1
There is no NEC acceptable use of “MCP” (Magnetic-Only) circuit breakers outside of a listed factory assembled and tested combo starter. The only reason they are sold is (ostensibly) as direct exact replacement parts.
kwired
Electron manager
NE Nebraska
+1
Which also probably means you wouldn't even find one with jaws for plugging onto I line bus, I would think. Usually would be a unit mounted in a MCC bucket and would have lugs on both ends of the breaker.
