I am currently in the process of converting our facility from T12 lighting to T8. I have four rooms with split 2 x 4 troffers. 2 lamps are on a dimmer. The dimmer is an old Leviton 6675 rotary switch that states that it is only to be used with Universal 502 or 550 magnetic dimming ballast. 502-A is what is currently installed. I am upgrading with Philips Advance Powerline Mark 10 electronic ballast. Question is, do you see any reason why I can't reuse the old rotary with the new electronic ballast? This is a hospital application and a newer deco style is not needed. Simple is better in this case.
